Boilsoft Audio Converter is designed for you to extract or convert audio from all popular video and audio formats to fashionable audio formats, such as AAC, AC3, AIFF, APE, AU, FLAC, M4A, MKA, M4R, MP2, MP3, OGG, WAV, WMA, RA, and etc.
The joyful sound that makes you feel comfortable, from either your favorite movies or your beloved songs, can be converted to music in a trendy format.
As a universal and versatile software, our audio converter spare no efforts to provide you with a series of practical features, ranging from editing and cutting segment you want to convert, setting the expected volume of audio, to customizing the sample rate, Bit rate and channels the audio will contain. Metadata information of the output audio format, such as title, author, comment, album, track, can be customized as you like. Batch conversion is also supported. Our versatile bulit-in player helps you to preview the files in various formats! With one click on the interface, moreover, you can listen to the newly converted melody.
With a super intuitive interface, Boilsoft Audio Converter enables you to use it smoothly and efficiently without any tutorial. It is truly the audio converter that you want to use and never disappoints you!
;em03;;em03;;em03;;em03;;em03;;em03;;em03;;em03;;em03;;em03;
Functions:
* Support all popular video and audio formats, including 3GP, AAC, AC3, AIF, ALAC, AOB, APE, AMR, AU, CD Audio, DIRAC, EVO,WV,IVF, M4A, MOV, MP3, MPA, NUV, MPC , TTA, TS, WAV, PVA, RA, Real Media, SD2, SHN, MKV, DivX, DVR, FLAC, FLIC, FLV, MKA, MP4, MPEG, OFR, OGG, OGM, SND, TIVO, Video CD, VOB, VRO , Windows Media, WMA, WMV.
* Output formats can be AAC, AC3, AIFF, APE, AU, FLAC, M4A, MKA, MP2, MP3, OGG, WAV, WMA, RA, and etc.
* Metadata information of the output audio, such as title, author, comment, album, track, can be fully customized as you like.
* Sample rate, bitrate, and channels can be completely personalized according to your own preference.
* The expected volume of ringtone can be set from 0%-200% (default setting is recommended).
* Support batch conversion- save you a lot of valuable time.
* High-speed conversion!
* Listen to tracks prior to conversion
* More advanced options to configure the audio quality.
Homepage:
http://www.boilsoft.com/audioconverter/index.html
Functions:
Homepage:
