AKVIS Coloriage 7.0
Info:
The new version of AKVIS Coloriage - Coloring book program for black and white photos and replacing colors on color izobrazheniyah.Dostatochno few strokes to designate sites for repainting and run the calculation. Coloriage recognizes the borders and paint the image, superimposing color with light texture, light and shadows.
Coloriage is extremely easy to use, requires no special effort, transforms the work into the game, drawing and inspiring. The main problem - the separation of areas and choice of colors. Just a few strokes to designate sites for repainting and run the calculation. Coloriage recognizes the borders and paint the image, superimposing color with light texture, light and shadows. This automatic colorization significantly saves time!
The program includes a rich library of colors to choose delicate shades of skin, hair, foliage, sky and other natural colors. It is possible to save and load "finishing touches", one click to change the selected color. Additional tool - repaints brush - allows to correct the result of automatic coloring. Also, the brush can be used as a standalone tool for coloring by hand.
Scope Coloriage is very extensive. The program allows you to colorize old black and white scanned images, to replace some color on color digital images, manipulate images, adding color to them (anime, comics, cartoons).
The program greatly facilitates the work of the designer in the selection of colors interior and exterior of the building. Not only can you learn practical benefit from the application program, but also get pleasure from it. After Coloriage allows you to experiment with the choice of shades of hair and costume.
The program can easily re-paint as a separate subject in the image and the image as a whole, will breathe life into the picture 100 years ago!
AKVIS Coloriage is presented as a plugin to image editors, and as a separate, autonomous programs. Works with images RGB (8 / 16 bits), supported formats are JPEG, TIFF, BMP, PNG. When you load the program image in color model CMYK, Grayscale, Lab, etc. is automatically switching to RGB. Coloriage plugin can handle almost any file that opens a graphical editor from a list of compatible (including. Psd), mode RGB.
In version 7.0:
-Changed the program interface (new design), change the icon of the application. Screenshots.
-For pencil adds a new mode - mode of multi-color, you can draw several colors at once. Also on the panel settings, added variety of color palette to manage the new regime. Mode iridescence easier to work with complex patterns and objects with clear boundaries, where it should be noted in pencil a lot of different areas, such as tree branches against the sky, a bush with flowers, the button on his shirt. Textbook.
This mode is available only for "advanced" types of licenses (Deluxe, Business).
-Improved compatibility with the Windows 7 or Snow Leopard (Mac OS X 10.6)
In the plug-in added support for 64 bit (compatibility with Adobe Photoshop CS4 64 bit).
Plug-compatible with Adobe Photoshop Elements 8.
New installer for Windows.
Be sure to remove (through Control Panel Windows) the old version before installing the new one.
-Improved print dialog (is possible to choose the printer and its resolution).
-Updated documentation.
Info:
In version 7.0:
代碼:
Download Link: (Rapidshare)
http://rapidshare-8.blogspot.com/2010/03/part1_3200.html
No Pass
